Please ADD & FIX For T56
To correct! Instead of 1.8V, the voltage is 1.5V
Add the ability to edit firmware (dump files or directly)
- open sections
- Edit partitions (for Android and other Linux systems)
- Definition of protective zones (calibrations, EFS, NVM, etc.) and read/Save file
- Finding informational data about the firmware (dump)
- Ability to upload(flash) factory firmware
- Erase user data (Factory Reset & Erase DATA)
Thanks
Oleg_Skalskiy 发表于 18-10-2022 21:30
may be into the box to make a modification?
回复  Oleg_Skalskiy
AMS1117-1.8V  is Is inappropriate.
need a LDO as XC6206 1.8V
admin 发表于 18-10-2022 08:43
    Thanks
回复 6# Oleg_Skalskiy
Hand mode VCCQ 1,5V 🤔
Test 发表于 17-10-2022 04:19
    I installed AMS1117 1.8V on the adapter
But the partition manager is missing
Add the ability to edit firmware (dump files or di ...
+ Ready to be a tester!
Maybe you need some modification of the box? Here on the forum, most of the engineers will be able to fix it!
only at 3.3V power ,VCCQ is valid.
