How unpack partition table from full dump NAND chip
Hi!
I need to make a copy of the Nand chip.
I can't write a copy to the new chip in "Hadr Copy" "Single File" mode because the new chip has a Bad Block.
I want to use "Partition Mode" and "Skip Bad Block" mode, but I don't know what partition markup is on the original chip.
How do I know/unpack a partition table from a full dump?
I read these notes and want to figure out what to do with such bad blocks :)
These two links talked about how bypass bad blocks  - write in Partition mode and skip bad blocks.
http://forums.xgecu.com/viewthre ... 1&extra=#pid747
http://forums.xgecu.com/viewthre ... ghlight=bad%2Bblock
Can you get ahead of what partitioning on a flash drive if there is only a full dump of it?
If I write only one section (the whole flash drive), how to correctly calculate the END_BLK and CNT_BLK values
I tried to record the chip in single partition mode for the entire volume (1024 blocks).
It successfully writes data to the partition but fails validation.
Programming Nand Flash : Succeeded. Time : 16.641 S --  Flash Size :135168 KB
Verifing Nand Flash ...
Block#252 Verify error Bytes: 1174
Verify Error Blocks: 1
At the same time, the Bad Block list is empty.
I think my programmer can't identify a faulty block when programming (6.4.7.1) in this situation.
How can I manually mark/add Bad Block it to the Bad Block List?
I cant upload images - Adobe Flash Player does not work now:(
