The data for T56 in this table are valid only at the beginning of the appearance of T56. At the time of release of T48, these data are incorrect.
Once I managed to fix the maximum speed for T56 (for work with EMMC) - 32 Mbytes/sec. But this was at the beginning of the T56 release. With the first version of the BGA153 adapter. Then, after a new version of the software appeared, the first version of the adapter BGA153 stopped working in 8-bit mode. Only version 2 of the adapter worked in 8-bit mode. Then, most likely, the software limitation of the maximum speed of the T56 happened. After that, the speed of T56 with eMMC did not exceed 15MB/s. |
