Program problem PC28F256P30BF (BGA64)
Unfortunately, I'm unable to program PC28F256P30BF (BGA64) with adapter XG-BGA64P2-1.0mm
Each time I have error buf_val 0xFF but ic_val 0x00 with different addresses.
I unsoldered all capacitors and checked. Capacitance is 0.1uF of each.
What else can I check?
The back of adapter C1,c2  C3 all is 0.1uf.Have them been soldered  on?
Unfortunately, the length of the cable is 8 cm (cable comes with adapter)
回复 5# Test
Please cut the ISP cable length to below 10CM.
Your error is similar to mine. Pay attention to the firmware erasing time
Admins did not answer anything for 2 months with a similar problem.
http://forums.xgecu.com/viewthread.php?tid=1059&extra=page%3D1
Chip erased with T56 and blank verified on other programmer successfully.
Chip programmed and verified on other programmer.
Then I read chip on T56, after I pressing verify I got error on address A, I close verify window, open it again, press verify and got error on address B, ....... got error on address C.
I bought a programmer from another manufacturer with an BGA64 adapter, PC28F256P30BF was erased and programmed normally.
I repeat the same procedure on the T56 and I have error.
回复  Test
I did not find any errors during my testing.
admin 发表于 2023-7-21 17:01
    As a User,
                   Hopefully is only a bad contact or resistance, on adapter side or chip side. Try cleaning both , or chip first, then the socket , then the rest.
Be carefully all the time
Hope it helps
回复 1# Test
