反应个问题,有时候打开后找不到程序界面
有好几次电脑开机后打开主程序没看到主程序窗口,然后看到一个类似输入法指示条的小框框,把小框框最大化了后才正常,系统是装好的没多久的WIN10,试过两台电脑都经常出现类似问题。
回复 2# Albano.Matos
   Thank you, I will observe for a while
同WIN10 64位  经常出现这个问题 ,有时候打开正常  有时候需要最大化
回复 3# admin
   :D两台电脑都发生过这个情况,不过最近暂时没发现这个现象
回复 1# izma669
这个情况会不是安装文件夹权限不够?
把安装文件夹,所有的用户权限改为完全控制
Several times after the computer booted up, I opened the main program without seeing the main program window, and then I saw a small box similar to the input method indicator bar, maximizing the small box ...
izma669 Posted on 2022-12-28 09:18
Hello: As an user.... I've had this problem some time ago. What I've done to get it back to useful state.  Found the small Xgecu window and manually maximize it pressing the maximize icon near the corner ,
and then, after it maximized, resize the window to proper and workable size. Close completely Xgecu,
wait a few seconds. start again Xgecu and see if open in the right place were it closes and the same
window size.
In my case it restore working order, narrow down , the most probable cause, to my HD620 intel
video drivers.
Do not forget to restart computer, in win10 restart only complete if a restart is done , shutting down machine
and power on is not a restart, like in Win7.
Hope it helps
