How to Adjust voltage in SPI mode
Hi, Is there a way to adjust voltage while using SPI mode (in circuit reading)? There are few eeprom's i need to lower/raise the voltage to read and writing and can't seem to find where to change it. There's menu to adjust current, but i need voltage. I have the T48.
   Thanks
Important feature for the eeproms i work with, automotive. Some i need to lower voltage to read and can't find a way to do it with T48. Please add function when/If possible. Thank You
回复 1# TonyD
This function is not available yet. we will consider adding this option .
