ST NAND512W3A2SN6
Is the ST NAND512W3A2SN6 supported?In the last software I can only see:
NAND512W3A2A
NAND512W3A2B
NAND512W3A2C
Can you confirm if
NAND512W3A2S
is supported?
In the affirmative can you please advise what the selection should be?
In the negative can you please add the support for the mentioned chip?
Thanks  and regards
Sergio
回复 4# Sergiosat
No problem
I read NAND512W3A2S using NAND512W3A2B and NAND512W3A2C settings.Adapter T56 TSOP 32/40/48/56
File was read and verified with both settings.
Output file are identical.
Would it be reliable?
Thanks
Sergio
Unfortunately I cannot find A2A in the list for NAND512 only for 128 and 256.What can I do?
Thanks
Sergio
A2S  is same with A2A
