T56,XGecu BGA24 and Spansion S25FL256S
Hello guys,
1: I bought this adapter from the official website:
XGecu BGA24 - DIP8 6x8 mm, 5x5 and 4x6 ball universal adapter IC socket.
2: I need to read this Spansion chip:
S25FL256SAIHC0 (see the photo).
3: I want to know: what is the correct orientation/position for the XGecu BGA24 adapter in the T56 programmer?
It won't read this Spansion chip in any position!
The T56 software doesn't specify which position I should use for this XGecu BGA24 adapter.
Looking forward to your reply.
Thanks.
modificado 2.jpg 回复 5# Albano.Matos
   Guys,1: This is the correct position for reading and writing to this chip.
2: I tried all other positions, but they didn't work; then I found this one.
And now, with this position, I can read and write.
回复  Albano.Matos
   Alright guys,1: So, the way to connect the XGecu BGA24 adapter
#: is in ...
barto44 发表于 2026-11-18 21:34
Hello,        Please, pay attention to the words, and also the image that is in the software.
You need to understand both, if not, it will not work for sure
回复 3# Albano.Matos
#: is in this position.
#: Now it should be able to read the Spansion chip. modificado.jpg
[цитата]Привет, ребята,
1: Я купил этот адаптер на офици ...
Igor 发表于 2026-11-18 14:20
Hello, just based in the photos you sent,
you are trying the adapter the wrong way. The 8 pin side, should be inserted in the other top of 48 socket, opposite to the latch. Even if you insert
the right adapter, and insert the IC in the right orientation, you will get warnings at
all pins the way you seem to be trying.
Hope it helps
1: Я купил этот адаптер на официальном сайте:
XGecu BGA24 - DIP8 6x8 мм, 5x5 и ...
barto44 опубликовал 18.11.2026 в 05:16 [/цитата]
