T76软件V12.79 win10专业版22H2提示有病毒
选的是 lanzout.com的链接
回复 3# Igor
thanks
回复 4# Albano.Matos
As you said,the problem was resolved after upgrading the anti-virus software.thanks
Trojan:Script/Wacatac.B!ml显示是上面这个木马
Test 发表于 2025-1-20 19:56
    Hello,             Unfortunately, AV software have it's defects, many times are called 'false positives'.
In my case, i had warnings showing up, with version 1270, 1275, and 1277,but not with
version 1279, it means that it took some time for AV manufacturer to know about, and fix issue.
Results vary from user to user, Yours depend of brand and update of AV software.
I found that, eprom programmer software, and Infrared software programming compatible
remotes, Like GBS, have a tendency to show up those false positives, maybe caused by a
compressed algorithm, that store like the signature they have to trigger alerts, but it can't
found nothing after the program is installed if you allow it to run.
Never put your guards down, av attacks are serious, and i've warn this issue on other post.
T76 programmer - 编程器使用与软件下载 - XGecu Programmer Forums - Powered by Discuz!
There is no Trojan there.
But you can unpack both archives in winrar manually.
