OK guys a new update on my bricked T56.I got the PICKIT5 programmer and connected to J1.
Here below ...
Sergiosat 发表于 2026-4-22 01:32
         After jumper pin 2 and 5 , connect cable, switch on and verify in device manager, if the device is recognized there in any way, or if yellow exclamation mark
is there, and if it is try verify/changing the driver, or with a clean install the xgecu app in another machine, and try there with new cable.
Driver is called Xgecu WinUSB Device , mine is at version 1.11.9200.16384.
Hope it helps
Hi Albano,did all test with different computers and cables with no success.
No way to have it recog ...
Sergiosat 发表于 2026-4-23 01:57
   Hello Sergio,
1- Try xgecu Support at 532007590@QQ.com and/or xgecupro@gmail.com and ask for help, maybe they still have parts
     if needed.
2- Upgrade the unit to the new T76, T56 is already out of production, as it give more current
     to program better newer ICs at XGecu T76 USB3.0 Universal Programmer support EEPROM NOR NAND EMMC MCU GAL;Minpro/TL866II/T56 programmer Replacement IC tester , new adapter investment maybe needed, Adapters for XGecu T76 Programmer
Never use Usb Hub, unless external powered, and that hub connected to a machine port directly.
To help all of us, please, share and post here the solution you may find, also share channel you get answer, please.
Best Regards
Hello Albano,I already emailed the tech support 3 times, but have not yet got any answer. Hope they  ...
Sergiosat 发表于 2026-4-24 03:24
   Hello Sergio,                      I miss to add http://forums.xgecu.com/viewthread.php?tid=791&;highlight=telegram
I've not been there ever, but can also be another source for other users help, if you have an account and if still active.
Hope it helps
