回复 1# kuzma2000
Please read carefully, Chapter 6: NAND/ SPI_ NAND Programming of the user Guide
NAND/ SPI_ NAND Programming Notes:
1. It is possible that the speed of programming the chip is faster than reading , because the software automatically skips the content of the empty data during programming.
2. In the process of reading, erasing , or programming, if chip has bad blocks, the tip will appear, but i t does not affect the programming of the chip.
3. It is not necessary to check the bad block before copying. As long as the verifying is correct and there is no error when programming, the new copied chip will be available. If there is a bad block in the new chip, the software will skip writing if the bad block is empty data when copying. If the new chip has a bad block, and the original chip has data to be written to the location of this bad block, the data can’ t be written into this bad block, the programming error will occur. Please replace with another new chip, (the location of the new chip bad block’s position is generally random).
4. Repairers usually do not know how to deal with bad blocks, so only copy directly with hard copy mode |
