XGecu Pro 不能正常读写M24256E2Prom芯片
如题,XGecu Pro在读取M24256时,总是提示过流或者芯片短路,芯片在希尔特500P上读写正常,没有问题。请咱们的技术人员把这个BUG解决了吧!
如题,XGecu Pro在读取M24256时,总是提示过流或者芯片短路,芯片在希尔特500P上读写正常,没有问题。请咱们 ...
diodes_1 发表于 2025-1-8 22:06
   Hello,            You have the possibility to adjust manually the 'VCC Current Imax:  ' in small increment steps.
If you have time, as you know the chip is good, change a bit the parameter, and post here the results,
please.
Rgds
