can I change EN29LV320CB to 5V in Xgpro?
I have a game cartridge PCB with an EN29LV320CB (TSOP-48) mounted on the board. The PCB is designed for a 5V power supply and 5V bus interface. It has level shifters. Also, pin 47 (BYTE#) is tied high.
I can build an adaptor from the PCB edge connector to the T56 socket. But can I configure Xgpro to use 5V instead of 3.3V?
