Logging and JTAG
Hi, can you add copy function for log window?  Or the ability to save the log to a file.  I would also like to be able to disable automatic log clearing. And log text output from the programming reading windows to the main log.  I also wanted to ask if it is planned to add the jtag function and the ability to change the cid emmc.
回复 1# STALKER_71
jtag function will be added in the future. but change CID of EMMC
it is special funtion? do you have Docs about changing CID via JTAG?
it will be added to save the log to a file.
Disable log auto. clearing : Not a good suggestion, it will take up a lot of system memory.
Thanks for the answer. JTAG in the future it's a good news. Change cid not via jtag but via direct connection to emmc.  On emmc samsung z3x can do it.  This is very necessary when the device firmware has a binding to the cid.  Disabling autocleaning of the log can be done as an option that will be disabled by default.  Whoever has a lot of system memory and who needs it can turn it on.  This is convenient when you work a lot with different types of IC.  Especially with EMMC.  Logging to a file can partially solve this problem.
