I have tried 1 bit, 4 bit, 8 bit, lower VCC, lower clock and reading errors persist. Is there any way to fix the errors?
log is:
APP Version : 12.45 Model : T56 MFG:2022-03-06
Device : H26M52103FMR_8Bit @BGA153
Pins Detected Passed!
Init EMMC... OK! ( OCR register: C0FF8080 )
Reading ECSD : Succeeded
RPMB Protected by Authentication Key ,Operation OK
RPMB Writer Counter : 3680
C:Calcu.available disk capacity: 264 GB
Reading BOOT1 : Succeeded. Time : 0.281 S -- Partition Size :4096 KB
Reading BOOT2 : Succeeded. Time : 0.281 S -- Partition Size :4096 KB
Reading RPMB :Succeeded. Time : 1.641 S -- Partition Size :4096 KB
Reading User Area : Succeeded. Time : 2744.360 S -- Partition Size :15392768 KB
Reading Succeeded 32 bits CheckSum : 0x A89B5F9D
All saved to the folder: C:\TL866II\UserData\EMMC_Data
Verify Restart EMMC ....
Verifying CSD Succeeded
Verifying ECSD Succeeded
Verifying BOOT1 : Succeeded. Time : 0.282 S -- Partition Size :4096 KB Processing Size from the File : 4096 KB )
Verifying BOOT2 : Succeeded. Time : 0.296 S -- Partition Size :4096 KB Processing Size from the File : 4096 KB )
Verifying RPMB :Succeeded. Time : 1579 ms -- Partition Size :4096 KB
Analysis file is complete, Space usage: 72.72% time: 76S
Verifying User Area ...
Verify Error at Address 0x00_00000C32: Source data: 0xD3 -- Target data: 0xC3
Verify Error at Address 0x00_00000C44: Source data: 0xCA -- Target data: 0x4A
Verify Error at Address 0x00_00000C59: Source data: 0xAA -- Target data: 0xBA
More lines like above..........................................
The number of incorrect data is greater than 32 .
Verifying User AreaFailed Error Counter: 99797161 |
