EMMC UserData.BIN access to data/convert to mountable image
I need your advice. I'm newbie.
I did EMMC dump I have UserData.BIN (size almost 16GB)
Data on this EMMC is FAT32 partition.
Disk is not encrypted.
I want to have access to files by mounting image to system then do some modification in files and then convert it again to bin file and program to the chip.
How to do it?
BR,
STr
PS I have no possibility to use emmc to sd card
Additional information:
APP Version : 11.90 Model : T56 MFG:2021-03-04
Device : THGBMHG7C1LBAIL_8Bit @BGA153
1 Programmer Connected.
Device 1: XGecu T56 Ver: 00.01.55
USB POWER VOLTAGE: 05.02V
USB SPEED MODE: HS 480MHZ
< Analysis IC >
Pin Detected Passed.
* Clock Frequence is 8.000 MHZ *
1..Emmc Initialization ......
OCR register : C0FF8080
2..Read device CID .......Successed
3..Read device CSD .......Successed
4..Read device ECSD ......Successed
<1> -- Production Info.and Device life time--
MID : 11
PNM : 016G30
Product Date : 12-2016
Version : MMC V5.1
Device life time Type A : 0%-10% device life time used
Device life time Type B : Not defined
Device life time (PRE_EOL_INFO) : Normal
<2> -- Partition Size Info.--
BOOT1 SIZE : 4096 KB
BOOT2 SIZE : 4096 KB
RPMB SIZE : 4096 KB
GPP1 SIZE : 0 KB
GPP2 SIZE : 0 KB
GPP3 SIZE : 0 KB
GPP4 SIZE : 0 KB
USER SIZE : 15,388,672 KB
( 0x 03_AB40_0000 )
1 . BOOT1 Partition Not be Permanent write-protected, it can be Read or Edited or Erased.
2 . BOOT2 Partition Not be Permanent write-protected, it can be Read or Edited or Erased.
3 . GPP1 GPP2 GPP3 GPP4 The Partition Invalid
4 . USER Partition Not be Permanent write-protected, it can be Read or Edited or Erased.
5 . RPMB Partition is Blank, not be Used.
6 . This chip's content can be completely copied to another chip . |
