TL866, TL866 II and T48 programmers not support Atmega2560 MCU
While the simple USBASP programmer supports ATMEGA 2560, why do the TL866, TL866 II and T48 programmers I have not support the Atmega 2560 chip? I kindly ask you to take it into consideration in the next software updates. Best regards.
While the simple USBASP programmer supports ATMEGA 2560, why do the TL866, TL866 II and T48 programm ...
profesor 发表于 2025-2-1 08:10
Hello,         As a user, i see no programmer support all ICs, and many try to do it ... slow. Most of times
i see they are doing the progress of work, starting with adapters that are available for this or that programmer.
The Atmega 2560, is, based in the datasheet a family with at least 5 different ICs based in 2 sockets,
ATmega640/1280/1281/2560/2561, one with 100pins, and another with 64, and maybe others, that not show
up in the available portfolio of the programmer brand, or universal adapters, most of time done for 'Arduino fans'. Some ICs, also allow
programming with wires, trough ISP interface, with /without an available/self made adapter, as they have available on T48,T56, and
the newer T76.
In the last case, or else,  if not showing up in the support list, just ask here to add the support like you have done, and wait, lately they are a bit slow doing that. As an alternative, if you buy programmer, or else, from certain resellers/partners, like LRF is the professional supplier of laptop chips in China , they, hopefully, can give you much attention then here and may, or not, help
to narrow the time gap for support availability, as i feel, the actual focus, appear to be now for new T76, Haikou Xingong Electronic Co,Ltd  .
Hope this helps :) , or not :(
