XMC25RH256C *
HI . I ASK WHY T48 NOT SUPPORTED XMC25RH256C .... I cant read or write on this chip ....
Reply  Albano.Matos
   the chip is xmc25rh256c
cgtecINFO 发表于 2023-3-20 03:35
   Hello,           Have you tested, removing the check id tab selection at bottom of screen?
If ID isn't correct, only Admin can correct it, but maybe functional if you unselect it.
Please test to see if any other event presents to you. Admin for sure , time permites, will fix
any error. T48 is now very popular, then needs better attention :-)
Reply 2# Albano.Matos
   itry version 12.50 not ok to read or write xmc25rh256c ... i read and write same dump  motherboard not working
cgtecINFO 发表于 2023-2-22 19:58
   As a user: IC XM25RH256C*, but not XMC25RH256C* from XMC, appears to be supported on Xgecu software version 12.50. if the reference is right, if you select it, you got any error?If yes, please post print screen image  to get help, please.
Rgds
