ROSATOMFLEET
hello again, this is first priority:We need to check with TL866 II the next chips:
- DP8304BN
- D3-4702-9
- SAB8288AP
- P8284A
- N8T95N
- N8T96N
- SN74LS368AN
- SN74LS365AN
- M5832 (OKI)
I repeat, I can PAY you for this job if you asked. We need it ASAP because this list for atomic icebreaker "Varzuga"!
my e-mail: sergey.cherkasov@ru.abb.com
Answer me on my e-mail please ASAP.
The most rest chips we have checked well by using yours device (TL866II - good device really, thanks).
I think you will choose this as a first priority, because this is for atomic icebreaker.
Hello anyone??? Is there will be any feedback or not?? This is 5 minutes work for making IC tests of that list, is that a big problem for ypu??? If it is then give me the instructions how to write pgrogram for IC test!!
Adding the test of logic chip, there is no time to do it now. In the future(in next month), we will use the user-defined function. Use the vector table for testing. You can add the test function yourself.
Hello, so, if i correctly understood: you are going to make an update, where users will be able to add new chips and add new algorytms for them? Because now i tried to ADD NEW CHIP but nothing results.
Untitled.png this function now doesn't work, could you describe how exactly should I adding new chips (now it's just copying reference chip with a new name and nothing , I can't change the program test logic)
回复 5# SergeyCherkasov
this is only for memory flash.logic IC testing be not ready yet.
hello again, We need to check with TL866 II the next chips:
- DP8304BN
- D3-4702-9
- SAB8288AP
- P8284A
- N8T95N
- N8T96N
- SN74LS368AN
- SN74LS365AN
- M5832 (OKI)
How long should I wait for this? If you have a little time then give me the instructions how to add it by myself?? I really need DP8304BN, SAB8288AP, P8284A, N8T95N, N8T96N, SN74LS368AN, SN74LS365AN.
I have been waiting for 4 months allready!!!
Varzuga is tanker, not icebreaker
thank you. I think I will be able to test by myself 8304BN, but i still need help with SAB8288AP
and P8284A. What about them? It's not an IC logic (probably) (there are drivers for 8086 processor)
回复 10# SergeyCherkasov
Logic testing  only test  simply logic chip. Other types of chips can not be tested.
Thanks, all i need is done)
