More than 32 errors reading EMMC
I have tried 1 bit, 4 bit, 8 bit, lower VCC, lower clock and reading errors persist. Is there any way to fix the errors?
log is:
APP Version : 12.45   Model : T56  MFG:2022-03-06
     Device : H26M52103FMR_8Bit @BGA153
Pins Detected Passed!
Init EMMC... OK!    ( OCR register: C0FF8080 )
Reading ECSD : Succeeded
      RPMB Protected by Authentication Key ,Operation OK
      RPMB Writer Counter : 3680
C:Calcu.available disk capacity: 264 GB
Reading BOOT1 : Succeeded. Time : 0.281 S -- Partition Size :4096 KB
Reading BOOT2 : Succeeded. Time : 0.281 S -- Partition Size :4096 KB
Reading  RPMB :Succeeded. Time : 1.641 S -- Partition Size :4096 KB
Reading User Area : Succeeded. Time : 2744.360 S -- Partition Size :15392768 KB
Reading Succeeded 32 bits CheckSum :  0x A89B5F9D
All saved to the folder:  C:\TL866II\UserData\EMMC_Data
Verify Restart EMMC ....
Verifying CSD Succeeded
Verifying ECSD Succeeded
Verifying BOOT1 : Succeeded. Time : 0.282 S -- Partition Size :4096 KB Processing Size from the File : 4096 KB )
Verifying BOOT2 : Succeeded. Time : 0.296 S -- Partition Size :4096 KB Processing Size from the File : 4096 KB )
Verifying  RPMB :Succeeded. Time : 1579 ms -- Partition Size :4096 KB
Analysis file is complete, Space usage: 72.72% time: 76S
Verifying User Area ...
     Verify Error at Address 0x00_00000C32:  Source data: 0xD3  -- Target data: 0xC3
     Verify Error at Address 0x00_00000C44:  Source data: 0xCA  -- Target data: 0x4A
     Verify Error at Address 0x00_00000C59:  Source data: 0xAA  -- Target data: 0xBA
    More lines like above..........................................
  The number of incorrect data is greater than 32 .
Verifying  User AreaFailed  Error Counter: 99797161
Is there any way that I can mount the file with errors on a disk? The T56 output a 15GB bin file, if I can mount the file I could recover some data, is an Android device, Thanks
