How to add XMC 25RH256CXIQ ?
DjamelGsm 发表于 2023-1-13 06:41
    As a User: Have you tried latest software 12.45? Download Newest XGecu T56/T48/TL866II software(下载最新软件) - 编程器使用与软件下载 - XGecu Programmer Forums - Powered by Discuz!
XMC 25RH256C* is available for all Xgecu programmers. Any error? Post images, please!
Hope it helps
XMC 25RH256C* is available for all Xgec ...
Albano.Matos 发表于 2023-1-13 14:43
Always use the latest update
  1. APP Version : 12.45   Model : T56  MFG:2020-10-27
  2. Device : XM25RH256C* @WSON8
  3. Pins Detected Passed!
  4. Check ID Error!
  5. Checked ID is:0x 20 43 19
  6. Wish to continue programming , please cancel [Check device ID] option!
复制代码
DjamelGsm 发表于 2023-1-13 17:38
   Hello,             I see now. Some times with so many IC variants, the ID present in the software,
is only from one IC, sometime something is wrong and need to be corrected,
and to work, need removing check ID tag, at bottom of window. Can you, please try it?
For sure, time permits, Admin will help further.
Just trying to help
i try to unchek ID . i read dump but its crupted .... there is problem . i try w25r256 work perfect
