support m48z58
Is it possible to read my chip
on the TL866II plus?
https://www.st.com/resource/en/datasheet/m48t58.pdf
https://www.st.com/resource/en/datasheet/m48t5 ...
TV13M 发表于 2023-1-6 14:14
   As a user: Are you using latest software version 12.45? Do you have any error? any annoyance, or bad result? Please, describe better step by step what you are doing. With the free software, you can simulate the programmer you already have, or not. It's not the same as real work, but may answer some questions.
Hope it helps :-)
2023-1-6 18:14
I've seen that title. But, because it's a different manufacturer, I was afraid to install my chip. The device where my chip is installed partially works.
I haven't done anything yet.
The m48t58 from manufacturer ST has a different function on one of the pins,
and m48z58 from manufacturer SGS-*** - I couldn't find the documentation.
I've seen that title. But, because it's a different manufacturer, I was afraid to install my chip. T ...
TV13M 发表于 2023-1-9 15:12
   Hope it helps you M48Z58Y-SGS.pdf (132.45 KB)
