ATtiny configuration suggestion
As of now, the configuration bytes are set by checking boxes for each parameter, and then the program calculates the config bytes for you. Would be nice with possibility to do it the other way around too, by simply entering the desired configuration bytes.
See the attached screenshot for an example. If I wanted the depicted configuration, I'd simply enter 7A, F4, FD for low fuse, high fuse, and lock bit respectively in text boxes, instead of checking the parameter checkboxes.
This would simplify things when using an external calculator to calculate the config bytes.
