Increase of the list of history and the menu for working with eMMC
1. Please increase the history list of the latest chips. For example, up to 20, like RT809H. A list of 10 entries is no longer enough, since the program is used for three programmer models at once.
2. Please make the program remember the last folder that was specified for the location of the files in the eMMC menu "Options - 4. File name / Path / Address assigned - File derictory:".
Saving file folder path for eMMC doesn't work again in 12.63.
For 3 months you have not been able to fix a simple software defect.
Saving file folder path for eMMC doesn't work again in 12.60
Why didn't you add path saving in version 12.59?
Do you like it when clients constantly tell you about software defects?
This again does not work on 12.57. Please fix this.
Hi.In version 12.50, to select the "My favorites" section, you need to scroll up the list each time. This is very inconvenient for working with the "My favorites" list.
2023-2-21 11:29
it takes time just like selecting a chip manually
回复  Test
   The ADD function can be used as a favorite function.
admin 发表于 2022-12-8 09:26
Clarification on the second request, it means that when you click on the "Select derictory" button,  ...
Test 发表于 2022-12-7 22:26
OK
回复 1# Test
2022-12-8 09:26
2022-12-8 09:26
Clarification on the second request, it means that when you click on the "Select derictory" button, the last used folder opens immediately.
