need help first time using t 48
need help connecting this to my t48  do i can read that chip
2022-12-1 04:38
2022-12-1 04:38
2022-12-1 04:38
2022-12-1 04:38
回复 1# ghades
The use of test clips is unreliable.
what's the IC name?
ghades 发表于 2022-12-1 04:43
Hi, please don't use it, it won't work in the circuit. Use the socket and the removed chip, this is the only way to achieve 100% success. If all the same it is very necessary to consider the dump without soldering. You need to use the port ICSP
