adesto at45db321e write problem
APP Version : 12.35   Model : TL866II Plus
     Device : AT45DB321E[Page528] @SOIC8
Note:
Must Connect a 100P Capacitor between Pin MISO and Gnd!!!
and  Connect a 2.2uf Capacitor between Pin VCC and Gnd!!!
All right, i go to the steps. Step by step.
Pins Detected Passed!
ID: 0x 1F 27 ......OK!
Erase  ...Succeeded. Time : 40.576 S
Programming FLASH ...Succeeded. Time : 52525ms
Verifying FLASH ...
ERROR!   FLASH Address:0x001EF0    Buf_Val:0xE6    IC_Val:0x06
Programming  ...Failed
why does the programmer not write the chip? if I use another programmer other than xgecue, everything is written and there are no errors.
Help me!!!
Hi, I bought T56 and there are no such problems with it, I also found a problem with the definition of pages, tl866 did not give the correct definition of pages
回复  Dmitry
MISO is SO . Not SI.
admin 发表于 2022-11-15 11:11
Forgive me for typing, of course, SO leg. Error has not changed
回复 3# Dmitry
Hi Admin, of course I connected these capacitors, 100pF between SI and ground, 2.2uF between Vcc and ground. Nothing changed.
回复 1# Dmitry
TL866II Must Connect a 100P Capacitor between Pin MISO and Gnd!!!
If possible, please use T48 programmer, which is quite stable without adding capacitance.
