Probleme with emmc with vccq =1,8v cant detect with supp or isp.
Hi, problem with emmc have vccq - 1.8v, can not detect, it gave me the initial emmc and failed - error: 00FF8081, when I use an external 1.8v, it tries to read the information, read cid csd successfully but error to read ecsd and failed - no data response state: I tried to measure vccq either in isp or on the emmc support , it is either absent or it is of low value -max 1.4v-.
2020-7-29 23:18
2020-7-29 23:18
2020-7-29 23:20
2020-7-30 22:33
think you , problem resolu 👍👍👍👍👍 after checking ic6202 , all ok reading and programming .
2020-7-30 22:33
2020-7-30 22:34
Maybe it's your adapter problem.   1.8V is powered by U4  LDO   XC6206-1.8V on EMMC adapter.
check IC :XC6206-1.8V
when choice VCC3.3/VCCQ1.8V . programmer's VCCQ PINS(2# 3# of P2) is Is high resistance state.and 1.8V power by XC6206.
if choice VCC3.3/VCCQ3.3V   VCC and VCCQ powered by programmer.
this is EMMC adapter SCH.
2020-7-30 13:21
