After firmware upgrade the "check device ID" can't be performed
I have upgrade XGPRO software today ( to version 12.01 ) after that i received a request to upgarde also Firmware of the TL866II PLUS
during the reflashing the indicators went very slow... (on last 2 years this process was very fast)
after flashing there was a message like "can't restart programmer"
and now i have this issue on "check device id"
there is a way to FORCE a new reflash (maybe using another USB prot with another chipset)
is this the correct pinout?
nevermind... yep, just tried, and the squared one is the 1 :) thank you again for the support!
Very thank you!
回复 11# Bartoloni
Open the cover of  the programmer .there is a 6P connector,  short PIN2 and PIN5.  then plug into USB.
you can reflash now!
回复 10# Evcon
:( i think i will do a firmware reflash using the DavidGriffith opensources utilities... but i'm little worried about the bootloader or losing  the serial number...  ican't wait 6 months to reflash with next official update :(
This programmer has a forced firmware programming mode. You need to ask the forum administrator for help.
Sure:
Bartoloni 发表于 2022-6-21 18:40
Open full screen. At bottom, you have a tap to disable ID check. It helps?
Post images
Can you upload a screenshot
Sure:
回复 6# Bartoloni
   Then in what case do you get the error? Can you upload a screenshot of the error?
sure :)
here you are:
the system self-check is also reporting everything NORMAL.
Can you take a screenshot of the program after executing the Help-About command on the failed 866?
i need to wait next official firmware upgrade ?
meanwhile i bought another TL866II Plus ... i think this device is very useful and i need it...
there is a way to duplicate the firmware from my new device to the old one?
回复  Bartoloni
reflash it.
The "reflash firmware" is grayed out beacuse the firmware is the latest one ( 04.02.129 ) .. i need to to overwrite it with the same firmware (and i will use a different computer with a different USB chipset)
there is some sort of extra command to force the re-flash??? something like: xgpro.exe /force  ???
回复 1# Bartoloni
reflash it. donot use external USB hub.  or do it on another computer.
