L56R memory support
L56R memory support
Hi I ask if it is possible to have L56R memory support i tried to do the reading using 93C46, 93C56, M93C56, M93C56R, BR93C56, BR93LC56 (RF), but the test gives me different readings, you can add the read / write support for this device?
I am attaching photos and drawing of the upper / lower side and dimensions
I am waiting for an answer
A thousand thanks.
Tonino.
2022-6-4 18:55
2022-6-4 18:55
2022-6-4 18:55
L56R memory support
Hi I ask if it is possible to have L56R memory support i tried to do the read ...
tonino 发表于 2022-6-4 18:56
    As an user....Have you tried with BR93L56Rx (not LC) from manufacturer ROHM (Xgpro 11.90)?
Hope it helps :-)
回复 2# Albano.Matos
test with BR93L56 (RF) or BR93L56 (F)
2 chips pinout is diffrent.
Thanks for the replies, my experience had the same reading with soic8 support, Microchip 93C56 (x16), Rohm BR93C56 (X16), BR93L56 (RF) (X16), BR93LC56 (RF) (X16), ST M93C56 (X16) , M93C56R (X16), then I chose the modified, programmed ST M93C56 (x16) reading, reassembled everything "successful". Thanks a lot for the technical support.
