Winbond W25Q128JVSM - Unknown device
Hello, please help, programmer (TL866II and T56) doesn't understand this chip (Unknown device) Winbond W25Q128JVSM.
Datasheet:
https://datasheetspdf.com/pdf/1462140/Winbond/W25Q128JVSIM/1
回复  Albano.Matos
Thanks for the answer. I tried remove the selection from the checkbox "Chec ...
AWENA 发表于 2022-2-14 20:15
Dear Awena,
                   Please, try to post the image or text with text ID value. Some ICs are
rebadged as other manufacturer, with new markings printed in. Please post the new ID
you found on your IC. ADMIN will tell, something about it, hopefully.
Rgds
回复 2# Albano.Matos
Thanks for the answer. I tried remove the selection from the checkbox "Check ID" and it helped.
Hello, please help, programmer (TL866II and T56) doesn't understand this chip (Unknown device) Winbo ...
AWENA 发表于 2022-2-14 15:29
    As an user.....Have you tried to add manually the IC, not automatic?
I can see that is in the list with software for version 11.81. If any error message post here, please.
Hope it helps
