回复 1# madkingmy
I don't understand what you said, (byte swapping)
This programmer show HEX in 16 bits mode about 16-bits chips, and there is a switch between 16-bit and 8-bit display in the upper right corner of the window. This is only the show HEX mode is different, the content is the same after saving to the file or programming to the device.
EXAM:
8 bits MODE     0x12 0x34  0x56  0x78
16 bits MODE   0x3412      0x7856
This is a basic data show hex format that has no effect on programming the device, nor on saving files.
回复 4# madkingmy
   this function is useless, what do you want to  do?
回复 6# madkingmy
I can add byte swapping in the next version.
But,
The original datas or the datas read are all in normal order. Many programmers also have not this function.(Usually it's just a display mode switch, 8bits or 16bits)
why do this?
