Please HELP me with Sharp LH28F320BJE-PT
Hello.
I have Sharp LH28F320BJE-PT
Flash Memory 32Mbit (2Mbit x 16/4Mbit x 8).  I can read it, I can erase it, BUT i can't programm it.
Here is my log
APP Version : 11.60   Model : TL866II Plus
     Device : LH28F320BJE-PT @TSOP48
Pins Detected Passed!
ID: 0x00B0 00E2......OK!
Programming FLASH ...
Programming  ...Failed
I've tried different IC types and find out that if I select LH32F800BGE-B (512Kbit x 16).  I can programm the first 512Kbit of this flash and I've checked, the data is OK.
Please help me!
Hello.
Flash Memory 32Mbit (2Mbit x 16/4Mbit x 8).  I can read it, I  ...
ancc78 发表于 2021-11-13 14:03
Hello,Please post the adapter you are using, V1base, V2 base, other?
回复 2# Albano.Matos
   I used V3 (TSOP48/SOP44) adapter(SN001-1) with TSOP32/40/48 adapter (SN003)
回复 1# ancc78
Carefully handle the connection of pins and socket pins.
First 512kbits is normal . so bad pins is A18/A19 address pins ?
I've checked several flash chips. I think this is can't be a adress pin problem, because  can read flash wih any problem. Test for pin connection shows no error. Also, I get programm error immediatly when starting to program. I also noticed, that LH28F320BJE-PT and LH32F800BGE-B have different algorithms. The first uses Flash16bit , and the second NorFlash. May be this is the problem?
Hello. Is it possible to solve my problem?
Hello. I've checked v.11.70 and the problem still exists. Can you tell me if this problem will be fixed next version, or I have to go and buy another programmer?
回复 7# ancc78
   I bought a sample for testing, there is no problem
