Help to clone emmc Sandisk SDINBDG4-8G General Purpose Partition
Hi, I don't know if anyone here, user or staff, can help me with the following problem.
It turns out that I need to clone an emmc sandisk sdnibdg4-8g that has Gpp1 configured with 2gb, I can read it without problems but when I generate EMMC_Ghost.mpj to write a new emmc sandisk this gpp partition is not written, it just copies boot / user partitions.
I make it clear that the emmc to write is new from the factory and of the same model, it does not have the Gpp areas previously configured, I understand that the gpp partitions are programmed only once and cannot be reverted [/ b]
EMMC_Ghost.mpj&ECSD_CSD&Log_txt.zip (3.83 KB)
Sorry I already understood the problem, I was not very clear about the function of rst_n 0x01 which I cannot modify to write gpp I must have ruined ext csd when I try to clone the emmc's with another programmer thanks for your answers I received other emmc's and no I had problems
they can close the topic :victory:
Read extcsd from emmc ic where you dont can crate gpp partition and post here.
STALKER_71 发表于 2021-11-3 07:55
okay!
ECSD_CSD.&LOG.zip (1.97 KB)
回复  arrobazo
I use a other EMMC , test it with your configration ; GPP1 greating is normal.
p ...
admin 发表于 2021-11-2 10:04
Thank you very much, if you want I will send you my backup if you want it or when you get your emmc sandisk ... I appreciate your support
回复 6# arrobazo
2021-11-2 10:03
please wait for my order of SDINBGD4-8G
why can't I write gpp1? what should I do ? if my emmc does not have the gpp area configured
If in your emmc extcsd partition_setting_completed =0x01 you dont can create GP partition
回复 3# arrobazo
This problem is the failure of GPP1 config partition.
I checked the program and no problems be found. I tested it is no problem on other EMMCs, Partition config is normal.
I will buy  SDINBDG4-8G samples for testing.
回复  arrobazo
1. you first open project before progamming.
2. To write a new GPP partition, a  ...
admin 发表于 2021-10-31 17:44
    Thank you first for taking the time to help me ...
Well I loaded the project and then I start the programming but I have the following error, I attached pLog and screenshot.
I clarify that I have new emmc and all have the same problem.
P_log.zip (816 Bytes)
回复 1# arrobazo
2. To write a new GPP partition, a  new chip ( GPP no configed ) is required.
If a old chip is used for writing, the GPP configuration of the two chips must be exactly the same.
The most important : you need give  an error message when writting.
