T56使用HDMI测试视频信号失败
VGA模式下测试通过HDMI下使用了3台不同的显示器均测试失败 显示器提示无信号,我有5个适配座 所以可以排除适配座的问题
1台是7寸显示器 屏幕分辨率1024*600
1台55寸TCL电视 最大分辨率4K
1台65寸创维电视 最大分辨率4K 已经将电脑的HDMI 2.0和HDMI 1.4模式都测试了 均无信号
可以通过HDMI来读取到显示设备的信号,以下是HDMI1.4 最大2K模式下读取到的显示器信息,请管理员帮助判断问题在哪
************************************************************** APP Version : 11.20   Model : T56      Device : EN25T80 **************************************************************  读取设备的信息 (EDID) on Port: HDMI EDID信息长度 : 256 Bytes  Monitor Descriptor and Vendor information      NAME: Skyworth TV  Manufacturer Name: SKY Product Code: 0001 Serial Number: 01010101 Week of Manufacture: 7 Year of Manufacture: 2018 EDID Structure Version : 1.3  Basic Display Parameters and Features Video Input Signal Type: Digital Interface signal compatible with VESA DFP 1.X: Compatible Max Horz Size (in cm): 0 Max Vert Size (in cm): 0 Gamma Value: 2.20 Feature Support (DPMS)       Standby Mode: Not Supported       Suspend Mode: Not Supported       Active Off Mode: Not Supported       Display Type: RGB color display       Color Space: Alternate       Preferred Timing: 1st DTD       GTF Timing: Not Supported Color Characteristic Red_x: 0.639 Red_y: 0.330 Green_x: 0.299 Green_y: 0.599 Blue_x: 0.150 Blue_y: 0.059 White_x: 0.280 White_y: 0.290 Established Timings Established Timings I        720 x 400 @ 70Hz IBM, VGA       640 x 480 @ 60Hz IBM, VGA       800 x 600 @ 60Hz VESA Established Timings II        1024 x 768 @ 60Hz VESA Manufacturer's Timings            None  Standard Timings Standard Timing 1       Horizontal active pixels: 1280       Image Aspect ratio: 4:3       Refresh Rate: 60 Hz Standard Timing 2       Horizontal active pixels: 1280       Image Aspect ratio: 16:9       Refresh Rate: 60 Hz Standard Timing 3       Horizontal active pixels: 1360       Image Aspect ratio: 16:9       Refresh Rate: 60 Hz Standard Timing 4       Horizontal active pixels: 1920       Image Aspect ratio: 16:9       Refresh Rate: 60 Hz Standard Timing 5       Horizontal active pixels: 800       Image Aspect ratio: 4:3       Refresh Rate: 60 Hz Standard Timing 6       Unused Standard Timing 7       Unused Standard Timing 8       Unused Block0 Detailed Timing Descriptor 1 DTD support timing: 1920x1080p@60       Mode         "1920x1080"     # vfreq 60.000Hz, hfreq 67.500kHz       DotClock     148.500000       HTimings     1920 88 44 2200       VTimings     1080 4 5 1125       Sync Profile     "+HSync" "+VSync" Block0 Detailed Timing Descriptor 2 DTD support timing: 1280x720p@60       Mode         "1280x720"     # vfreq 60.000Hz, hfreq 45.000kHz       DotClock     74.250000       HTimings     1280 110 40 1650       VTimings     720 5 5 750       Sync Profile     "+HSync" "+VSync" Block0 Detailed Timing Descriptor 3 Monitor name: Skyworth TV Block0 Detailed Timing Descriptor 4 Min. Vertical rate (Hz): 48 Max. Vertical rate (Hz): 76 Min. Horizontal rate (KHz): 15 Max. Horizontal rate (KHz): 85 Max. Supported Pixel Clock rate (KHz): 300 Default GTF supported Extension Flag: 1 EDID Block0 checksum: C2 Video Data Block      1920x1080i@60      1280x720p@60      720x480p@60 16:9      640x480p@60      720x576p@50 16:9      1280x720p@50      1920x1080i@50      720x576i@50 16:9      720x480i@60 16:9      1920x1080p@60      1920x1080p@50 Audio Data Block SAD1 support audio format: PCM, max channels: 2 SAD1 support sample rate: 32K 44.1K 48K SAD1 byte3: 0x07 SAD2 support audio format: AC3, max channels: 6 SAD2 support sample rate: 32K 44.1K 48K SAD2 byte3: 0x50 SAD3 support audio format: DOLBY, max channels: 6 SAD3 support sample rate: 32K 44.1K 48K SAD3 byte3: 0x01 SAD4 support audio format: DTS, max channels: 6 SAD4 support sample rate: 32K 44.1K 48K SAD4 byte3: 0x50 SAD5 support audio format: DTS_HD, max channels: 8 SAD5 support sample rate: 44.1K 48K 88.2K 96K 176.4K 192K SAD5 byte3: 0x01 SAD6 support audio format: MAT, max channels: 8 SAD6 support sample rate: 32K 44.1K 48K 88.2K 96K 176.4K 192K SAD6 byte3: 0x01 Speaker Allocation Data Block     speaker info: 0x01 H14b VSDB CEC phyaddr: 0x10 0x00  support max tmds clock: 225MHz Block1 Detailed Timing Descriptor 1 DTD support timing: 720x480p@60 4:3       Mode         "720x480"     # vfreq 59.940Hz, hfreq 31.469kHz       DotClock     27.000000       HTimings     720 16 62 858       VTimings     480 9 6 525       Sync Profile     "-HSync" "-VSync" Block1 Detailed Timing Descriptor 2 DTD support timing: 720x480i@60 4:3       Mode         "1440x240"     # vfreq 60.054Hz, hfreq 15.734kHz       DotClock     27.000000       HTimings     1440 38 124 1716       VTimings     240 4 3 262       Sync Profile     "Interlace" "-HSync" "-VSync" Block1 Detailed Timing Descriptor 3 DTD support timing: 1280x720p@50       Mode         "1280x720"     # vfreq 50.000Hz, hfreq 37.500kHz       DotClock     74.250000       HTimings     1280 184 40 1980       VTimings     720 5 5 750       Sync Profile     "+HSync" "+VSync" Block1 Detailed Timing Descriptor 4 DTD support timing: 1920x1080i@50       Mode         "1920x540"     # vfreq 50.044Hz, hfreq 28.125kHz       DotClock     74.250000       HTimings     1920 48 44 2640       VTimings     540 2 5 562       Sync Profile     "Interlace" "+HSync" "+VSync"  Total support 16 timings:     640x480p@60     800x600p@60     1024x768p@60     1280x960p@60     1280x720p@60     1920x1080p@60     1920x1080i@60     720x480p@60 16:9     720x576p@50 16:9     1280x720p@50     1920x1080i@50     720x576i@50 16:9     720x480i@60 16:9     1920x1080p@50     720x480p@60 4:3     720x480i@60 4:3
回复  Test
这个都试过的,软件不会有问题的
1.适配座的电阻不要焊错!
2.测试分辩率及信号,要选择HDM ...
admin 发表于 2021-8-22 15:35
   经过检查 你说的对 确实是电阻有问题,看来淘宝购买的电阻并不可靠,R2的240欧电阻经过万用表实际测量为通路状态 更换一颗240欧电阻后视频信号输出没有问题
回复  Test
这个都试过的,软件不会有问题的
1.适配座的电阻不要焊错!
   电阻123使用240欧,其余电阻使用120欧,
我这里有近百根19芯HDMI 数据线,数据线在机顶盒上可以正常使用,
明日工作时 我将录像记录下测量适配座上的所有电阻以及hdmi信号测试的全过程。希望可以帮助排查问题
保存出来的显示器信息文本排班有些乱如果软件保存的时候可以用0D 0A 换行标志进行分割拼接下就好了
Test 发表于 2021-8-22 15:35
都加了的,这是DZ论坛软件的问题
回复 1# Test
这个都试过的,软件不会有问题的
1.适配座的电阻不要焊错!
2.测试分辩率及信号,要选择HDMI:1280x720
3.用优质的HDMI线
