Some ic's to add
Please add:
Atmel 24C08N
Intel JS29F32G08CAMC1 TSOP48
GD25Q21B
Please add FM25F04A
Please add GD25Q41B
GD25Q41B.pdf (846.08 KB)
Thanks! For wery fast adding.
回复 8# STALKER_71
OK
Add please winbond 25q64jw series
W25Q64JW_RevB_11042019-1760399.pdf (1.56 MB)
Greate work. Thanks.
回复 5# q519948746
这个功能一值放在计划里面,有时间就添加
回复 4# STALKER_71
   这个意见我也提出过,可惜没有得到管理员的回复。这个功能 认为还是很重要的,毕竟友好的交互体验也是加分项
Perhaps it is worth adding a separate "user add ic" group to the microcircuit search table in the program.  And so that the program would search for them too.  Because it is not very convenient to select them through the add tab.  Moreover, you often forget whether you added such a microcircuit or not.
They are the same.
回复 1# STALKER_71
OK
Is 24C08N different from 24C08?
