回复 9# yovish
I know the reason that it can’t be automatically identified
Because this chip is actually as shown in the figure below, these two pins are not used (NC). During the automatic find, check the number of pins. This chip is set to 14-pin in software, but it is detected that this chip is 12-pins, Only 12-pin chips will be tested in the software, so it cannot be recognized.
If you want to be able to identified automatically, the vector table is made by the 12-pins chip
This is a very special type
I will modify this vector table to make it be recognizable. |
