Please use the latest version of the application software, do not use the old version of the software:
download from:
WINXP/WIN7 Older system,There may be some software components missing. if the USB driver cannot be installed automatically, you can install the USB driver manually.
1.插上编程器,进入设备管理器,找到有感叹号的设备。鼠标右键点击,弹出菜单,点击 更新驱驱动程序
弹出如下对话框。(WINXP/WIN7 稍有不同)
点击:手动查找并安装驱动,不要自动搜索
Plug in the programmer, enter the device manager, and find the device with an exclamation mark. Right-click, a pop-up menu, click to update the driver
2. 选择,从计算机可用驱动程序的列表中选取,如下图
Choose from a list of available drivers for your computer
3、点击 从磁盘安装
Click Install form Disk
4、找到如下所示的驱动文件夹
Find the drive folder shown below (your softawre installation folder)
5、点击 :确定
Click OK
后面的安装将自动完成,安装完成后可能需要重启电脑
The following installation will be completed automatically, you may need to restart the computer after the installation is complete |
