TL866II cann't support >8Gb ICs.
You can calculate that the USB FS mode 12Mb / s, the fastest speed of TL866II processing NAND chip can only be 400KB / s 16Gb NAND about 2,200,000KB data. Just reading need about 5500S. whole process need about 4hours.
SO, It is impossible to let a 30$ programmer to support ultra-large capacity chips.
回复 3# sergey42
TL866II does not have enough stability to read NAND.
It ’s not that we do n’t want to support it. It really ca n’t  be supported. There are many problems. For example, it took you 2 hours to read it, and then it took 2 hours to verify. The result is wrong. I do n’t want to be complained by others.
