» tl866 plus problem nand
发表于 2020-4-16 08:42
marck3
Please send any pictures about error information.
发表于 2020-4-19 11:18
marck3
Please have a test for changing R1 from 3K9 to 470ohm.
and Please upgrade to the newest software.
发表于 2020-4-20 11:18
marck3
I had a test with TC58NVG2S3ETA00
and use 64MB file. Writting and verifying. and verifying again . there was no problem happend. Your problem must be the problem of signal disturb
Please do another test: change the capacitance C01 from 0.1u to 10uf.
this is my test result:
(64.42 KB)
2020-4-20 11:18
(56.29 KB)
2020-4-20 11:18
发表于 2020-4-21 08:14
I am sure this is a hardware problem .
(8.99 KB)
2020-4-21 08:07
the value of the file : 0xBF377B00
and read from chip: 0x20377B00
in fact: 20 is the next byte.
Nand chip received an additional interfering
clock signal when reading. so got a next byte value.
发表于 2020-4-21 17:27
If all NAND chips are wrong when testing, try it with another NAND Adapter.or you DIYT a adapter by yourself.
发表于 2020-4-24 08:58
Please wait, I will do more tests to see if I can modify the software at the same time to improve its adaptability to reading,
发表于 2020-4-24 13:57
This problem is not achievable with every chip.
After a day of testing, several possible causes were modified. I think it should be fine.
1. please download lasted software . and installation
2. replace R01(3K9) with 470ohm
3. replace C01(0.1u) with 2.2u
4. Connect a wire as shown in Pictures.
(43.15 KB)
2020-4-24 13:57
