回复 9# henry1234
Could you verifying again directly , after stopping. (Not Programming again). it will get more information .I had a test ,ervery thing is normal.(USE a 147MB file to test)
this chip has 2 bad blocks No.471 and No.675.
because use hard copy and datas can not be written into the bad block. so it is wrong at Block 471#
Maybe you used a bad adapter, can you re-solder and clean it,
