TL866 plus
Can anybody just help me to write K9F2G08U0C flash program in any way. please help me thanks
回复 11# henry1234
Please refer to this post, whether it can solve the problem of NANDhttp://forums.xgecu.com/viewthread.php?tid=28&extra=page%3D1
I replaced 3k9 with 470ohm, soldering the chip on the circuit and still programming stop.
回复 9# henry1234
Could you verifying again directly , after stopping. (Not Programming again). it will get more information .I had a test ,ervery thing is normal.(USE a 147MB file to test)
this chip has 2 bad blocks No.471 and No.675.
because  use hard copy and   datas can not be written into the bad block. so it is wrong at Block 471#
Maybe you used a bad adapter, can you re-solder and clean it,
2020-4-20 17:36
programming stop.
upload new picture about wrong message.you may not program it again.  just verify it directly.
I replaced the R01 3.9k with the 470ohm con updating the new version, it still does not work.
in the configuration section I have followed theinstructions, whether in the configuration section I did wrong. can you help meconfigure this K9F2G08U0C nand.
Thank you my friend.
回复 5# henry1234
2020-4-18 17:40
Please have a  test  for changing  R1 from 3K9 to 470ohm.
and Please upgrade to the newest software.
photo write error
Please upload pictures about error information when writting.
Read file ok, write file stop
Read instruction bout NAND Flash Programming in intstall direcrtory.
2020-4-13 11:13
