Help LH28F320BJHE-PTTL90.
Doesn't want to record, if you fill in a clean dump, then it is written, if the required error flies -
APP Version: 10.90
Device: LH28F320BJE-PT @ TSOP48
Pins Detected Passed!
ID: 0x00B0 00E2 ...... OK!
Erase ... Succeeded. Time: 48.189 S
Programming FLASH ...
Programming ... Failed
If you write as LH28F400BGHE or 160, then it writes normally, but there is a different amount of memory. I wanted to get advice on how to bind LH28F320BJHE-PTTL90 to the desired algorithm
Best regards, Sergey.
еmail: vast777777@yandex.ru
回复 1# Test
what's the model of programmer. we will test it.
TL866II Plus programmer
回复 3# Test
   I bought a sample for testing, there is no problem
