Logic Test - Files structure (*.lst *.lgc)
Can you describe the structure of the logicUser.lst file and *.lgc files?
I would also be interested in either more information about the format of the LST file, or a tool that allows you to IMPORT vectors.
Please describe to me the CRC32 counting process in more detail. This will allow me to better use the potential of this programmer as a logic tester, because you do not want to add the additional functions I have proposed (import / export to text files, http://forums.xgecu.com/viewthread.php?tid=185&extra=page%3D1).
Something is wrong with this CRC32 ...
In the "4052.lgc" file shown, the selected area is LOGIC_ITEM+LOGIC_VECTOR. The counted CRC32 is at the bottom and is different from that in the file?!?
4052.lgc (2.27 KB)
回复 4# yovish
CRC32 is all LOGIC_ITEM+LOGIC_VECTOR .The initial value is 0
1. From which areas of the file is CRC32 counted?
2. Is the space between LOGIC_FILE_HEAD and LOGIC_ITEM reserved for the future?
3. Can the space between LOGIC_FILE_HEAD and LOGIC_ITEM have random content?
4. How exactly is CRC32 calculated?
回复 2# yovish
#define LOGIC_UFILE_FLAG  0xABABABEE
#define MAX_LOGIC_ITEM  512
typedef struct LOGIC_ITEM_FILE_HEADTag
UINT AllCRC32;// all Items CRC32
UINT uiFlag;    //
LOGIC_UFILE_FLAG
UINT AllItemCnt;
UINT Res;
UINT ItemStartPos[MAX_LOGIC_ITEM];  //start postion in the file
}LOGIC_FILE_HEAD;
typedef struct LOGIC_ITEM_Tag
UINT Vector_Cnt;
char IcName[32];
BYTE VccVoltage; //0-3
BYTE AllPins;
BYTE Res0;
BYTE Res1;
UINT uiRes;
}LOGIC_ITEM;
typedef struct LOGIC_VECTOR_Tag
char _byte[24];
}LOGIC_VECTOR;
What I have been able to analyze so far...
