T76 programmer
Version of the t76 programmer, what are the new functions in this programmer, what sockets for chips to use?
Version of the t76 programmer, what are the new functions in this programmer, what sockets for chips ...
Dmitry 发表于 2024-12-23 03:53
   Hello,            Some news already here Welcome to XGecu Official Store    ....
Ответить 2# Альбано.Матос
Albano, thanks!!
Ответить  Альбано.Матос
Albano, thanks!!
Dmitry 发表于 2024-12-28 00:43
              As it's already on sale on Aliexpress, some pics and info in specifications partXGecu T76 USB3.0 Universal Programmer support EEPROM NOR NAND EMMC MCU GAL;Minpro/TL866II/T56 programmer Replacement IC tester - AliExpress 7
It also shows capable to mesure ESR, resistance and capacitance capabilities :-)
I also found , that Xgecu App for T76, isn't, at least already, shared with the previous programmers, and gave false positive for some AVs, not available yet on Xgecu page. Version 12.70
You read it very carefully! This one is an error message generated during the copywriting and translation process that didn't check out. I've sent it back to the merchant for modification and deletion. The T76 programmer doesn't have a function to measure ESR and resistance. Thank you very much for the reminder.
              As it's already on sale on Aliexpress, some pics and info in specifi ...
Albano.Matos 发表于 2024-12-29 17:47
   Hello,            T76 software, official 'early version' version 12.75, can already be downloaded here:
( did not yet include the user manual updated for T76 )
Links at top of page:
Hello,            T76 software, official 'early version' version 12.75, can already be down ...
Albano.Matos 发表于 2025-1-4 21:46
   New T76 -12.77 software version is out....still improving before i receive unit.
New features are added by flashing firmware, now at version 1.05. They are working fast
as promised by 'Blue text' in the adds. Pdf manual still in the works, but T56 manual still
have most features use described. Latest chips with 512GB , like GD25LR512xxx,
still missing, hopefully they will be available soon. Unfortunately, some AVs continue to
give false positives, and complain about available software. I've not tried to update Xgecu
app, direct from app. I'll try next time but with programmer disconnected, to see if it works
without popups. It works fast :)
Ответить 7# Альбано.Матос
Albano, hello, today I finally got my new t76, I didn't expect the case to be two-colored, I would have taken it in a brown case)). I will compare it with my t56, which I mainly use for nand chips and flash memory. I hope that they will add the ability to work with super I/O controllers, as well as with chips, errors for which users encountered
IMG_20250228_121656.jpg Hello. I bought a T76 progromator, it's very good. Please add the x88c64pi chip to the support list. I wanted to destroy the microcircuit, the programmer is asking for software updates. I will be very grateful to you. I've tried programming a few microcircuits.
quote]Hello. I bought a T76 progromator, it's very good. Please add the x88c64pi chip to the support list. ...
Evgeny 发表于 2025-3-5 13:28 [/quote]
   Hello,           All of us  waiting for development. Until new version , with new support was out,
maybe with new firmware version, we must wait. So far, you can see what's in the works, and
what's missing from plan, with BLUE printing from page Haikou Xingong Electronic Co,Ltd
Adding new ICs also important, but many old ICs need support to be completed before,
hopefully, works like the one you need.
I'll wait
I'll wait
Evgeny 发表于 2025-3-9 11:03
           Software 12.85 , only for T76, is out for use. Ive noticed they removed SRAM chips in the previous list,
as support still in 'BLUE PRINTING', they also published the List of Supported ICs and 88C64 is there. Only testing
to see if it works now for you. Firmware was updated to 1.07, number of ICs in the list is now a bit above T48 in
number, but some features of T48 not available in the T56, still in the works, then the list will have to grow a lot
in the future....just wait, they are working, it seems, to get job done a.s.a.p.
Thanks for the update. You can send us a list of chips?
Evgeny 发表于 2025-3-15 15:31
   Hello,            It's not correct to send you a list, or publish it here, because it can
become outdated as soon as i put here or send.
Please, download yourself using this link http://www.xgecu.com/MiniPro/T76_List.txt
Hopefully you can use this link for a long time, if manufacturer did not change the name.The link for the file, is also in the software download page, a little below the software links...
Rgds:)
thanks
Good day!
Please tell me when to expect the release T76 Programmer Manual (English )?
Thank you!
Good day!
Thank you!
Test 发表于 2025-3-18 12:54
        Hopefully soon. If You aren't familiar with old program versions of Xgecu, programmers, T48, T56 and TL866II, for operational work the application is almost
the same, the same functions at the same place, then you can use actual provisory manual
that install in the root of program folder, or download it at
http://www.xgecu.com/MiniPro/T56_TL866II%20USER%20GUIDE.pdf
.If you need to setup any external connection, select the IC, then near the bottom, select Device.Info tab, it
will display some information how to connect. You can also display, bigger images of those images, if you
browse the IMG folder, inside the application folder . There, you can also see previous programmer images,
as they also be used in some occasions.
Hope it helps till then.
        Hopefully soon. If You aren't familiar with old program versions of Xgecu, progr ...
Albano.Matos 发表于 2025-3-18 14:02
   Hello,            The T76 also, if you have the programmer connected to it, show some ongoing information
about features that still are in development fase, a bit of time outside initial schedule, but still already
above numbers of T48, but not support all ICs yet.
The T76 native adapters, are showing up, first BGA64 from 3 to 1, compared to T48, BGA48-63 now
also, so far, with only one adapter only, Big saving for some of us, BGA 153-169 and BGA221, hopefully,
like the T48, expected to sell in groups of at least four, with BGA 100 and BGA162. Anyway, a wish like
with the 'Medusa ProII' programmer, some new Chip formats with only one adapter, to save money, at least to
some of us.
Waiting....
Why support for all ITE chip had been removed in the v12.85 version?
Chip list is empty
Test 发表于 2025-4-3 07:41
   Hello,            Just guessing, but, as you know, T76 and T76 Software, are at the moment,
a working in progress project. The same was appended for SRAM chips, maybe also
other ICs, the support wasn't complete yet and errors still need to be corrected, as
well firmware need to be updated, in the ICs support list they write, ITE -> TESTING..
Xgecu gave 2-3 month preview time to complete all, but like all previews, are just previews,
and the project will take a little longer, hopefully...
For more professional computer repair works, people complement with the use other programmers
like SVOD4, or even more expensive ones, with dedicated and specialized hardware, but hopefully, T76 will do some
of that work in the future. Simply...to do it all, time is needed for development, and sell many to cover costs, till
then we must wait, future path isn't free :'(
Hello,            Just guessing, but, as you know, T76 and T76 Software, are at the moment, ...
Albano.Matos 发表于 2025-4-3 13:03
   Hello,            Today Xgecu software was updated for all latest devices. T76 (12.89)  setup grow up near 3MB in size.
ITExxxx reference disapear from list, firmware updated to 1.08, and welcome message is new, now say in 4 steps, previous 5...
User manual still is at T56 level, but not much difference needed so far :-).
IC Support progress a lot, but not yet on target for T76:
T48-35267 from 35138
T56-38062 from 37906
T76-36111 from 35186
Adapters for BGA48/63, 64 , 153/169 already exist, BGA221 already seen in Aliexpress,
not now, but still show on Myshopify Adapters for XGecu T76 Programmer   Soon expected
other like the one already shown in the program like BGA24 for PN27x ICs, appears not be the same
as previous BGA24 (5x5 and 6x4, maybe a new for all BGA24), BGA100 and 162, the emmc
SD adapter, like in T48 (as they will add support all T48 ICs), the VGA/HDMI
adapter (When support available complete development).
A wish is, they offer to sell already build cables, the one that connects the adapter to
the ISP Connector, to use the massive investment done on T56 adapters, even at lower speeds,
at least till all adapters are available and have fair price, or maybe to use much better, like
the T56 ssop56 with Zif socket, great product, as the new available for T76 need to solder the IC,
not very practical.
It's improving... Please, give your feedback if you know something more.
Hello,            Today Xgecu software was updated for all latest devices. T76 (12.89)  set ...
Albano.Matos 发表于 2025-4-10 12:31
   Hello,            Today noticed that the same Emmc 5 in 1 Kit available for T48, is now also available for T76...
in aliexpress, unfortunatly more expensive, and not  free sending :'(
Also available at https://xgecu.myshopify.com/products/emmc-bga-5-in-1-adapter-kit-ic-socket-with-dual-head-probe-for-xgecu-t76-programmer-support-bga100-bga153-bga169-bga162-bga221
