ERROR READING AND WRITING M27C1001 AND AM28F010
tl866 plus problem reading and writing memories M27C1001 AND AM28F010. You can only read and write on the old minipro in version 6.71. The old version 6.85 also read wrong The only thing that read and write correctly on the minipro tl866 was version 6.71.
Discover the translation above, I bought the tll 866 plus. However, he is not reading correctly and does not write the above chips correctly. I also have the old minipro tl866 version 6.71 and read these memories perfectly.
M27C1001 ERROR.jpg (355.57 KB)
Blank chip on the tl866. Example M27C1001 everything appears 20 05. FF FF should appear.
    Then you can see about this on the tl866 plus, sorry for the translation.
plcc32 ler errado.jpg (305.33 KB)
Test made with 3 different adapters. Everyone has the same error. I don't think it's the adapter. It is softwere. I have the old minipro in version 6.71 and read on the 3 adapters 100%. However, if I use version 6.85 in the old one, it also gives an error. it only works 100% in version 6.71.
I've tested everything here and don't read. I have the old minipro it reads beauty. I have the rt809h it reads beauty. However the xgecu minipro plus does not read.problem solved after several tests. really hardwere problem. Leaked transistor. Keeping pin 34 high at all times.
ok
error tl866 plus.jpg (288.7 KB)
