Xgecu T56 not recognized
hello i have xgecu T56 programmer and won't be detected with Usb Cable only tested on many computer and same .
when i add 5V from psu extern the programmer work and test ok .??
any suggest for any parts need to be replaced or checked thank you in advance .
ps: firmware was updated to laste version and not resolve probleme .
think have 5v from the usb cable not working good
iam novice on electronics repair
regards
hello Admin
Thank you so much for your message
and solution work great .
my programmer work again and connector solveed my issue .
many thanks boss you are awesome.
回复 3# foulou0238
Check this DC socket, it is possible that the contact is not working
hello mate,
thank you for your replay cable usb was tested on T48 programmer and working well .
i test 3 cables and 3 laptops but same probleme .
the programmer work only when 5v is connected from externel power supply .
if admin can give some solution i will be glade .
hello i have xgecu T56 programmer and won't be detected with Usb Cable only tested on many computer  ...
foulou0238 发表于 2023-5-28 01:26
As a User,
               already tested with a new cable? A spare cable still common in printers and scanners.If new cable works, but voltage in xgecu software is too low in the right pane welcome messages,
get a 'solid' cable to handle enough current to T56.
Hope it helps
