Device Logic IC Testing issue using ATF22V10C-15PC Pin 23 as Input/Output.
Do you have any idea what is causing this and how to correct this output state ERRORs?
"S-100 Dual IDE V3a board" uses two GAL22V10-15 Jameco sold me two PALCE22V10D-15PC as a substitute but the TL866II plus can't program that part as a GAL22V10. I got two ATF22V10C-15PC so I converted the PASASM PDS to WinCUPL .PLD to output a .JED file. Was able to Program the two GAL's with the Xgpro v12.50 TL866II plus firmware v04.02.131. To verify that they were programmed correctly I created two Xgpro Device Logic IC Tests for the two GAL's 。 Having problems with one of the equations in the 2nd GAL the truth table setup ERRORs with both output states.
Attached zip file contains the IDE_GAL2.PDS, .PLD, .LGC, and .JED files.
Tests:
           #1 Testing results ERRORs with both output states.
           #2 Same as #1 but swapped CS_8255 with bsVAL Result OK.
           #3 Same as #1 but removed the OR of CS_8255 Result OK.
           #4 Just CS_8255 Used both PALASM .jed & WinCupl .jed with the same Weird Result!
           #5 Same as #3 but replaced !BRD_SEL with PORT_AB Result OK.
Input:
PIN 4 = !ADDR_DR;
PIN 5 = sOUT;
PIN 7 = !pWR;
Output:
PIN 18 = !BRD_SEL;
I/O:
PIN 23 = !CS_8255;
Equation:
BRD_SEL = CS_8255 # ADDR_DR & sOUT & pWR;
Truth Table:
Convert To: !CS_8255 !ADDR_DR sOUT !pWR | !BRD_SEL
Start value: 0 0 0 0 | H
                    0 0 0 1 | H
                    0 0 1 0 | L
                    0 0 1 1 | L or H error
                    0 1 0 0 | H
                    0 1 0 1 | H
                    0 1 1 0 | L or H error
                    0 1 1 1 | L or H error
                    1 0 0 0 | H
                    1 0 0 1 | H
                    1 0 1 0 | L
                    1 0 1 1 | L or H error
                    1 1 0 0 | H
                    1 1 0 1 | H
                    1 1 1 0 | L or H error
                    1 1 1 1 | L or H error
                    *--No effect
Input:
PIN 2 = !bsVAL;
PIN 4 = !ADDR_DR;
PIN 5 = sOUT;
PIN 7 = !pWR;
Output:
PIN 18 = !BRD_SEL;
I/O:
Equation:
BRD_SEL = bsVAL # ADDR_DR & sOUT & pWR;
Truth Table:
Convert To: !bsVAL !ADDR_DR sOUT !pWR | !BRD_SEL
Start value:  0            0                  0          0            | L
                    0            0                  0          1            | L
                    0            0                  1          0            | L
                    0            0                  1          1            | L
                    0            1                  0          0            | L
                    0            1                  0          1            | L
                    0            1                  1          0            | L
                    0            1                  1          1            | L
                    1            0                  0          0            | H
                    1            0                  0          1            | H
                    1            0                  1          0            | L
                    1            0                  1          1            | H
                    1            1                  0          0            | H
                    1            1                  0          1            | H
                    1            1                  1          0            | H
                    1            1                  1          1            | H
#3 Same as #1 but removed the OR of CS_8255 Result OK. Input :
PIN 4 = !ADDR_DR;
PIN 5 = sOUT;
PIN 7 = !pWR;
Output:
PIN 18 = !BRD_SEL;
Equation:
BRD_SEL = ADDR_DR & sOUT & pWR;
Truth Table:
Convert To: !ADDR_DR    sOUT   !pWR         | !BRD_SEL
Start value:  0                     0           0        | H
                    0                     0           1        | H
                    0                     1           0        | L
                    0                     1           1        | H
                    1                     0           0        | H
                    1                     0           1        | H
                    1                     1           0        | H
                    1                     1           1        | H
#4 Just CS_8255 Used both PALASM .jed and WinCupl .jed same Weird Result!
Output:
PIN 18 = !BRD_SEL;
I/O:
PIN 23 = !CS_8255;
Equation:
BRD_SEL = CS_8255;
Truth Table:
Convert To: !CS_8255      | !BRD_SEL
Start value:   0                | H
                     1                | H
                                        *<--<< How can this happen ????
Input:
PIN 4 = !ADDR_DR;
PIN 5 = sOUT;
PIN 7 = !pWR;
Output:
PIN 14 = PORT_AB;
Equation:
PORT_AB = ADDR_DR & sOUT & pWR;
Truth Table:
Convert To: !ADDR_DR      sOUT      !pWR    | PORT_AB
Start value:  0                    0           0         | L
                    0                    0           1         | L
                    0                    1           0         | H
                    0                    1           1         | L
                    1                    0           0         | L
                    1                    0           1         | L
                    1                    1           0         | L
                    1                    1           1         | L
Reply 1# wfulk02
Curious.  Did you scope pin23, to see if it changed ?   Which programmer did you use ?
I did see this comment on the minipro chat, is it possible that pin is not testable ?
This can be used with any logic chip, when you have the respective test vectors.
There is a hardware limitation for chips with more than 32 pins, that not all pins can be tested.
Addit: I see a 74181 wiggles pin 23 as an input, so you could also run that vector test and scope an empty socket ?
The MC6821P is a 40 pin part, but that says T56 only.
