Nand Flash Edit Buffer MX30LF1G18AC
I read Nand Flash MX30LF1G18AC in the default file
Flash_data.bin
then I want to Edit Buffer for changing one or more words...like in picture
but when I save the new file modified...
this is the result...
the size is only 133kb and I can't use this file
for programming the New IC Blank Nand Flash...
How Can I resolve this?
Thanks
I solved it...I opened file with hex editor...then I modified bin file...
and I saved the new file...
then I loaded file in the XGECU software...
and it works perfectly....
