» Plz Add FMN4ET2TCK Nand BGA162
DjamelGsm
来自
Algeria
3 小时
DjamelGsm
发表于 2022-10-31 22:08
Hello Best Team
Plz add FMN4ET2TCK NAND BGA162
Datasheet:
https://cdn.datasheetspdf.com/pdf-down/F/M/N/FMN4ST2TCK-25IF-FIDELIX.pdf
Pin Configuration – 162Ball MCP(X8/X32):
(165.5 KB)
2022-10-31 22:07
Pin Configuration – 162Ball MCP(X16/X32):
(167.29 KB)
2022-10-31 22:08
发表于 2022-11-1 08:56
DjamelGsm
This is a NAND FLASH chip, and there is no plan to add it.
According to the existing functions, you can DIY an adapter from BGA162 to DIP48 and set the NAND parameters.
If you are professional。
