TC58BVG0S3HTA00 @TSOP48 NAND Fault...
My name is Jorge Mandoju i´m from Rio de Janeiro Brazil.
I trying to read a TC58BVG0S3HTA00 @TSOP48 NAND, i have a new update NAND adapter with R1-470 OHMS and C1= 2,2 microfarads.
My programmer is a TL866II Plus.
The read are fine, after the read and verificatios have a lot the block with problemms, i tryed with new NANDD ans two from a working device.
Please help-me i need to copy this NAND to save more three devices..
回复 3# admin
I made tests with one NAND K9F1G08U0B@TSOP48 with default settings and i can read without errors...
Thanks for reply,
I made tests with 2.5V, same faults :(
I think this is a firmware fault, some time ago was worked fine.
After new firmware upgrade no worked more, i used last time i august 2011.
回复 2# mandoju
TL866II Test with  VCC=2.5V
Error log.
APP Version : 12.25   Model : TL866II Plus
     Device : TC58BVG0S3HTA00 @TSOP48
Pins Detected Passed!
ID: 0x 98 F1 ......OK!
D:Calcu.available disk capacity: 583 GB
Reading Nand Flash : Succeeded. Time : 196.219 S --  Flash Size :135168 KB
Verifying Nand Flash ...
Block#0 Verify error Bytes: 2847
Block#1 Verify error Bytes: 342
Block#2 Verify error Bytes: 1105
Block#8 Verify error Bytes: 39
Block#9 Verify error Bytes: 961
Block#10 Verify error Bytes: 362
Block#12 Verify error Bytes: 1004
Block#13 Verify error Bytes: 3552
Block#14 Verify error Bytes: 4009
Block#15 Verify error Bytes: 476
Block#16 Verify error Bytes: 5
Block#17 Verify error Bytes: 130
Block#19 Verify error Bytes: 1030
Block#20 Verify error Bytes: 2389
Block#21 Verify error Bytes: 2245
Block#22 Verify error Bytes: 258
Block#23 Verify error Bytes: 426
Block#24 Verify error Bytes: 1
Block#25 Verify error Bytes: 186
Block#26 Verify error Bytes: 586
Block#27 Verify error Bytes: 144
Block#29 Verify error Bytes: 635
Block#30 Verify error Bytes: 38
Block#32 Verify error Bytes: 116
Block#33 Verify error Bytes: 92
Block#34 Verify error Bytes: 318
Block#35 Verify error Bytes: 969
Block#36 Verify error Bytes: 527
Block#37 Verify error Bytes: 1323
Block#40 Verify error Bytes: 921
Block#41 Verify error Bytes: 4738
Block#42 Verify error Bytes: 2348
Block#43 Verify error Bytes: 10
Block#69 Verify error Bytes: 60
Block#70 Verify error Bytes: 397
Block#71 Verify error Bytes: 1751
Block#72 Verify error Bytes: 870
Block#73 Verify error Bytes: 1990
Block#74 Verify error Bytes: 499
Block#75 Verify error Bytes: 792
Block#76 Verify error Bytes: 2269
Block#77 Verify error Bytes: 944
Block#78 Verify error Bytes: 1045
Block#79 Verify error Bytes: 1931
Block#80 Verify error Bytes: 306
Block#81 Verify error Bytes: 1420
Block#82 Verify error Bytes: 3172
Block#83 Verify error Bytes: 595
Block#84 Verify error Bytes: 2030
Block#85 Verify error Bytes: 1834
Block#86 Verify error Bytes: 602
Block#87 Verify error Bytes: 754
Block#88 Verify error Bytes: 2545
Block#89 Verify error Bytes: 3817
Block#90 Verify error Bytes: 3341
Block#91 Verify error Bytes: 564
Block#92 Verify error Bytes: 1735
Block#93 Verify error Bytes: 2272
Block#94 Verify error Bytes: 2533
Block#95 Verify error Bytes: 520
Block#96 Verify error Bytes: 3862
Block#97 Verify error Bytes: 1749
Block#98 Verify error Bytes: 530
Block#99 Verify error Bytes: 758
Block#101 Verify error Bytes: 408
Block#102 Verify error Bytes: 1751
Block#103 Verify error Bytes: 684
Block#105 Verify error Bytes: 162
Block#106 Verify error Bytes: 353
Block#107 Verify error Bytes: 2
Block#219 Verify error Bytes: 292
Block#220 Verify error Bytes: 588
Block#221 Verify error Bytes: 2
Block#222 Verify error Bytes: 2
Block#223 Verify error Bytes: 2139
Block#224 Verify error Bytes: 643
Block#226 Verify error Bytes: 704
Block#228 Verify error Bytes: 381
Block#229 Verify error Bytes: 106
Block#233 Verify error Bytes: 23
Block#235 Verify error Bytes: 4
Block#236 Verify error Bytes: 840
Block#237 Verify error Bytes: 273
Block#238 Verify error Bytes: 29
Block#240 Verify error Bytes: 469
Block#241 Verify error Bytes: 8
Block#243 Verify error Bytes: 2
Block#244 Verify error Bytes: 181
Block#245 Verify error Bytes: 773
Block#246 Verify error Bytes: 7
Block#247 Verify error Bytes: 294
Block#249 Verify error Bytes: 36
Block#273 Verify error Bytes: 2957
Block#274 Verify error Bytes: 2217
Block#275 Verify error Bytes: 4783
Block#276 Verify error Bytes: 2534
Block#277 Verify error Bytes: 1464
Block#278 Verify error Bytes: 3842
Block#279 Verify error Bytes: 2453
Block#280 Verify error Bytes: 249
Block#281 Verify error Bytes: 3406
Block#282 Verify error Bytes: 4147
Block#283 Verify error Bytes: 512
Block#284 Verify error Bytes: 2494
Block#287 Verify error Bytes: 1297
Block#288 Verify error Bytes: 1909
Block#289 Verify error Bytes: 1333
Block#290 Verify error Bytes: 949
Block#291 Verify error Bytes: 2219
Block#292 Verify error Bytes: 814
Block#293 Verify error Bytes: 2619
Block#302 Verify error Bytes: 16
Block#303 Verify error Bytes: 15
Block#307 Verify error Bytes: 3257
Block#308 Verify error Bytes: 962
Block#321 Verify error Bytes: 2202
Block#322 Verify error Bytes: 10333
Block#323 Verify error Bytes: 40
Block#324 Verify error Bytes: 1387
Block#325 Verify error Bytes: 1722
Block#326 Verify error Bytes: 149
Block#327 Verify error Bytes: 886
Block#629 Verify error Bytes: 581
Block#630 Verify error Bytes: 664
Block#631 Verify error Bytes: 660
Block#632 Verify error Bytes: 484
Block#633 Verify error Bytes: 638
Verify Error Blocks: 274
In options, reduce the speed or change VCC voltage to operate again
